Wheel Spacers
revhead347
Apparently my ex-husband made that mistake.
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Does anyone know what size wheel spacer I need to run a Weld Pro-Star 15 x 3.5 on the front of a 95' Mustang GT with stock brakes? Also, where is the best place to get them.
Thank you,
Kurt
this topic has been talked about alot in last few days do a search on wheel spacers, also some have to be ordered specifically for your car, some are universal but require longer studs. ran a search for you click on link and read threads if they don't answer questions run a new thread alot of good info. here. theres buisnesses in the threads in link you can call or e-mail to find out all info. you need.
http://forums.stangnet.com/search.php?searchid=986602
I have that same size wheel on the front and I cut the pad bracket bar off and used a 1/8" spacer. I have read on hear numerous times that you do not have to use a spacer if you cut the bar off but that depends on the thickness of your brake pads. If you have new pads the caliper will be closer to the wheel.
7/16" a huge spacer. I think if I put new pads on it with the 5/16" spacer that I got it will be fine. With the spacer it just rubs a bit, and my pads are old.
Thanks for the help.
Kurt
