Wheel Studs
  • Thread starter Thread starter dcurtis
  • Start date Start date Apr 19, 2008
dcurtis
688
Apr 19, 2008
  • Apr 19, 2008
Ok, I need new studs, longer ones than stock, I have weld lug nuts that are closed end design, they are the 1.380 shank length ones, I have rodlite wheels, does any one know what studs I will need for my car?? Stock studs are 2 1/8'' long overall, and 1 7/8'' underhead to tip long, and what size knurl also??
Bigstang1
415
Massachusettes
Jun 3, 2008
  • Jun 3, 2008
I am interested in this info too...subscribing
Redsnk95
2,243
Houston, TX
Jun 3, 2008
  • Jun 3, 2008
You will need open ended shank lug nuts with this swap. I don't know the knurl etc, but I called Maximum Motorsports and they sent me the correct ARP stuff. They are expensive but work great. Do not cheap out on the Moroso studs you have to drill out your existing holes for them to fit etc.
dcurtis
688
Jun 3, 2008
  • Jun 3, 2008
Sorry, I should have done an update but I have already done the stud swap, I got Moroso part #46185 for the front and Moroso part #46180 for the rear and I had to drill none of the holes, they fit great, and I even used the same lug nuts that I had on with the stock studs, which are the 1.380 inch closed end weld brand lug nuts, one of my lugs bottomed out on the stud when all the way torqued down, I just swapped it for anouther lug and that one fit fine, I guess one of my lugs were drilled just a tad bit less. Any how the 1.380 length lugs fit basically perfect with the moroso 46180 and 46185 studs and I did not have to drill my hubs for them to fit.
Oh, and maximum motorsports has the moroso and the arp studs, and they are the same size, that is where I found the studs for my car, I just bought them from summit racing cause they were cheaper there, but anyways size wise the arp and the moroso studs that m&m carries are the same.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Jun 3, 2008
  • Jun 3, 2008
3" long 1/2"x20 thread.
dcurtis
688
Jun 3, 2008
  • Jun 3, 2008
yep
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
