wheel tubs
  • Thread starter Thread starter bditty50
  • Start date Start date Sep 30, 2008
bditty50
170
Tampa, Florida
Sep 30, 2008
  • Sep 30, 2008
I'm wondering if its possible to put rear tubs on my car and fit custom 12 inch wide wheels without doing a narrowed rear end? I want to keep my MM rear suspension. I want the car to handle and not just be straight line but, I want those super wide tires.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 30, 2008
  • Sep 30, 2008
I dunno...i think you'd be faced with figuring out the back spacing and offset, and i think at the end you'd run into the shocks no matter what you did. Wider wheel wells is only half the problem.
69clark
731
Ravena, NY
Sep 30, 2008
  • Sep 30, 2008
I going to be running a setup like this soon (maybe upto 13"wide), but haven't started the fab work as I am still planning and measuring. You probably won't be able to use any of this copy cat bolt-on catalog parts stuff to do it, but it can be done. I don't want to let out the secrets to my plans, but if you want to do some custom stuff you can make it work.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 30, 2008
  • Sep 30, 2008
Is that for the Pacecar or the '95? I'm almost certain i've seen 12 inch rims on an SN95 already, maybe without a lot of mods if any. The wheel wells are a lot deeper.
69clark
731
Ravena, NY
Sep 30, 2008
  • Sep 30, 2008
The pace car.
Your right in that the 95 has quite a bit more room for wider meets though.
bditty50
170
Tampa, Florida
Sep 30, 2008
  • Sep 30, 2008
I just want the meats with out losing my track width. I want my MM 3 link to be free to move and I will be running coilovers. I just don't want to narrow the rear I hate all out drag cars they are so unfunctional and most don't see the strip that much.
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 1, 2026
limp
Cleaning up Aluminum
  • limp
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2026
KRUISR
H
Best tire size for 91 Fox 18x9 wheels. On coilovers
  • hassler
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
KRUISR
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
