Wheel ?
  • Thread starter Thread starter tkareno
  • Start date Start date Sep 10, 2007
tkareno
67
clinton ct
Sep 10, 2007
  • Sep 10, 2007
http://www.latemodelrestoration.com/...0 1&comp=LRS
I would like to run these wheels on my fox the car has a 5 lug conversion i am just wondering if i could run these no prob with no issues i will probably need wheel spacers but other than that do you guys think they would be a good fit?
__________________
bloopbloob
578
Alberta
Sep 10, 2007
  • Sep 10, 2007
you need to fix that link...
tkareno
67
clinton ct
Sep 10, 2007
  • Sep 10, 2007
ok heres the link http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=WTK-S1007AS 1&comp=LRS
tkareno
67
clinton ct
Sep 10, 2007
  • Sep 10, 2007
ttt
tkareno
67
clinton ct
Sep 11, 2007
  • Sep 11, 2007
ttt
tkareno
67
clinton ct
Sep 12, 2007
  • Sep 12, 2007
c''mon someone has to know the Answer to this
P
PJB
131
Rotterdam, NY
Sep 12, 2007
  • Sep 12, 2007
Get the right backspacing and you wont need spacers.
I put '03 wheels on my '92 and they fit without spacers. I just had to flip the quad shocks.
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Sep 12, 2007
  • Sep 12, 2007
which conversion do you have? if its the mark7 rotor job then youll have problems with fitting the centercap on the front.
id be more concerened with the tire sizes. a 265 is a VERY wide tire to be putting on the front of a fox, especially a pre-91, ive got a 245 on my 17" saleens and it rubs the front spats when turned too far.
a 285 in the rear should fit fairly easy (compared to a 315 anyway). the fender will probably need to be rolled and the inner fender may need to pounded a bit, as well as the quad shock flipped/removed.
tkareno
67
clinton ct
Sep 12, 2007
  • Sep 12, 2007
im not sure on the conversion i just bought the car and it had the 5 lug conversion on it
Mustang5L5
Mod Dude
Feb 18, 2001
43,343
18,074
224
Massachusetts
Sep 12, 2007
#10
  • Sep 12, 2007
  • #10
You need SN95 front conversion parts up front and out back you either need the 5-lug drum setup or any of the disk brake setups modified with the north race cars setup in order to retain stock rear fox track.
Spacers aren't a concern. The concern is that the wheel may stick out a little too far.
You may need to ditch your rear tailpipes and flip the quad shocks (or elim as last ditch effort)
Take some pics of your brakes and we can ID what you have
96SVTpilot
82
Spanaway, WA
Sep 12, 2007
#11
  • Sep 12, 2007
  • #11
Yes, yes, and yes. There are many different flavors of 5 lug conversions and you need to know which one you have. I tried that same wheel/tire combo on my 92, and it looked fine with good clearance. I'm not running quad shocks so can't help there. I didn't drive with them on so i don't know how well it would have turned with the 265s in front. I am running 94 spindles and fox length axles. If you are running 96+ spindles and 94+ rear end don't plan on running those wheels being tucked or even flush. They will stick out.
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
3K
Fox 5.0 Mustang Tech Tuesday at 10:18 AM
jaygee15
J
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
