wheels causing ticking sound
  • Thread starter Thread starter stang0f87
  • Start date Start date Apr 16, 2006
stang0f87
102
Fort Smith, AR
Apr 16, 2006
  • Apr 16, 2006
ok i've got 15*8.5 centerline warriors with 4.5" backspacing on my 87 gt. i got around the tire rub i believe but i'm getting a ticking sound thats bout to drive me nuts. seems like i read someplace that its caused by the caliper bolts. thinking bout grinding them down a little and see if that helps. it only makes the sound when i cut the wheels either direction. any ideas?
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Apr 16, 2006
  • Apr 16, 2006
I have the same problem but mine tick all the time. Someone told be it could be the cotter pin rubbing on the underside of the cap. I need to pop em off and clip them down a bit to see.
Clienterror
22
  • Apr 16, 2006
Once I was freaking out cause I could hear a ticking everytime my tire spun and it would speed up/slow down with me. Figured out it was a peice of gravel stuck in the tread rofl...just a thought if you drive on gravel any.
txstang84
1,639
42
69
Tuscola, tx
Apr 16, 2006
  • Apr 16, 2006
might also be bearings going dry...I had that problem before I went to 5 lug...hope not, but possibly
stang0f87
102
Fort Smith, AR
Apr 16, 2006
  • Apr 16, 2006
kinda doubt its the bearing though i'm not dismissing that possibility. just poked my finger through the wheel holes. don't feel like i got much clearance for the caliper bolts or the housing for that matter. it'll be ugly but think i'll grind a little off and see what happens
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
9
2016 GT with ticking sound form read end
  • 989153
  • Mar 21, 2024
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Mar 21, 2024
989153
9
C
Scraping sound while turning?
  • crazyone64
  • Aug 13, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2024
crazyone64
C
Did an auto reset procedure earlier, few questions
  • from6to8
  • Jun 19, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 19, 2024
from6to8
