Where can I get used TURBOS?
haulbalz
448
Where can I get some turbos for a twin turbo setup? Also, what size and other misc. parts would i need to make it work? Thanks for your help guys.
P.S. 1105- how is your setup comming along?
yea man check out turbomustangs.com and go to the classifide section and post a wanted add. I'm running two Garrett T3's .60/.63. For intercoolers I'm running two 1G DSM intercoolers one behind each foglight hole. Although they are pretty small, then are pretty thick. Heres a quick little list of parts you'll need
Turbos, Wastegates (if the turbo didnt come with one), Actuators (if the turbo didnt come with one), Piping, Shorty Headers, Upgrade your fuel system, Blowthrough MAF, clamps, hoses, fittings, oil feed/drain lines. I'm sure theres some things I'm forgetting, but check out the DIY/JY TT sticky at the top and do a search on turbomustangs.com and you will find a lot of usefull info. My car should be running and complete in a few more weeks. If you want, you can hit me up on AIM - GT1105
