Where does this go????
Yes, I believe it attaches to the EGR as you have it. One from that vac tree should attach to the rear of the upper intake. You should also have a small one about 6" long that attaches from the rear of the upper intake to the fuel pressure regulator. Then, I believe a couple more go to the smog...looks like you have one of them hooked up already. Is there another valve on the smog equipment for that broken white one to go on? If you're not using it, cap it off w/ a screw or something to prevent a vacuum leak.
:stupid:
loooks like you just hook that one from that valve back up to that white part comin off the tree. other than that the one that goes to your EGR valve looks kinked....might replace that. And last of all...one of the big circles in that vacume tree is plugged. It looks like you have it empty which is good..
:stupid:
other than that the one that goes to your EGR valve looks kinked......
Yupe it was kinked and broken. I taped it up, and taped the other 2 that wern't hooked up. Car was running fine, so will see if it runs better. Those wires being unhokked or broken, how would it make the car run??????
