Where does your clutch grab?
If it's on the floor it either has air in the lines or the clutch friction plate is worn. The master cylinder is inside the car above the clutch pedal. It should be completely dry. I've done atleast 10 that had a leaking slave cylinder and it would cause similar issues. Would get air inside that would make the pedal really low.
Reactions: 93CalypsoConvert
Update: I found this thread here, https://www.mustangecoboost.net/threads/urgent-clutch-line-loose.9289/ that showed clutch line fitment. I checked mine and sure enough it was leaking, which means it was probably sucking air. I pushed the line up and pumped the clutch about 150 times. This completely changed the clutch. It feels like I'm driving a different car. Gear changes are much easier. It used to be near impossible to get it in first before completely stopping. Also, cold shift crunch is gone.
I guess my synchros have been working overtime... oops.
