Electrical Where Is It
bertman
55
Portsmouth Va
In the pic that i posted, can anybody tell me where that risistor is and its purpose. I have an 87 mustang. Just curious
That is a 22,000 ohm resistor for the IDM (Ignition Diagnostic Monitor) circuit that tells the computer that the PIP sensor is working correctly. Note that the diagram below shows it's approximate location.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
Should be along the firewall. I cant remember if the circuit from the TFI to the coil or the circuit coming from the coil to the tachometer has the splice in it. But its typically by the firewall, somewhere in the vicinity of the vacuum tree.
