89 vert, I do not know where the power window relay is nor do I know what it looks like. Thank you
Thanks Ken,gcw,
I might be off on the terminology about what you are looking for, but there is a power window breaker mounted up on the rear stud of the starter solenoid. The rectangular silver box mounted on the rear stud in the engine compartment controls the power to the windows on convertibles.
Without knowing the problem you are having limits the help, but wanted to make sure you were aware of that breaker up there.
Good luck,
Ken
The Power Window Safety Relay should be behind the driver's side kick panel.
The CB in the motor will protect the motor, but the CB in the fusebox on the 2 & 3 door protects the circuit outside of the motor. Probably in case of a wiring short or a catastrophic motor failure.
The Power Window Safety Relay is only used on the vert. The circuit has made use of the inline breaker at the starter relay in addition to the one used in the fuse box and added an additional relay.
I posted the convertible PW schematic back in this thread.
http://forums.stangnet.com/showthread.php?t=715792
