Where is the MAF?
Not sure I understand your description - 90 engine/tranny in an 81 body?
The maf should be located in the air inlet piping in between the throttle body and the air filter. Hard to miss - has a plug from the wiring harness plugged into it.
here is a pic of the stock setup
Pre 89's were speed density engines, exluding California 88 cars. Another way to check to see if your car is speed density is to see it the BAR/MAP sensor is connected to the intake. It's the black box thing mounted on the firewall right behind the upper intake.
HEHE You want to keep your TPS Voltage at .98v's Try this....
1- Unplug you battery and wait 5 minutes as well as disconeect the IAC connector.
2- reconnect the battery only and start the car, Set the idle you want with the set screw.
3- Turn off the car
4- reconnect the IAC and set your TPS Voltage to .98 volts(It may take a few tries but it will work, unless your running VERY rich then you would have to try other things such as replace your O2's and such)
91ghp5.0 said:
thats speed density. and is that an 81, or a 91?
(IN SPANISH)
Factura del mustang:
Mustang Mod. 1981 tipo Fast Back, 2 ptas aut, motor 8 cilindros, capacidad 5 personas, color ebano. Equipado con aire acondicionado, calefacción elevadores y seguros eléctricos.
Y la factura de la conversión a 1990, de Junio de 1991 dice:
Conversión a Mustang GT 1990 de mustang sedán 2 ptas. mod. 1981 con número de serie: xxxxx (el mismo que la factura)
Conversión exterior:
2 Spoiler's
1 Cofre
2 Calaveras
2 Faros
4 Cuartos
2 Facias
1 Tablero completo
Consola
1 Juego de calaveras
2 Espejos
1 Juego de molduras
1 Transmisión automática *
1 Motor de inyección **
1 Arnes electrico
1 Computadora
1 Juego de forros de asientos
System MAP only Mustang 86 to 88, then my engine is 1988? (I checked VIN engine and maybe 86 or 88)
