Where should I set my FP and timing at?
  • Thread starter Thread starter Limp Fox
  • Start date Start date Sep 28, 2009
L
Limp Fox
31
Newmanstown PA
Sep 28, 2009
  • Sep 28, 2009
Pretty much done with my HCI swap and ready to start her up tomorrow. Just have to install the Radiator, Electric fan and the Electrical fuel gauge. Just wondering where I should set my Fuel Pressure and timing at?
If it helps the Engine mods are below:
AFR 165 heads with 1.6 7/16 stud mount Rockers, Ed Curtus custom street beast cam (566ish lift and 224 duration, Edelbrock 5.0 intake, lower ported to match AFR's, 1" spacer, FRPP Red top 30lb injectors, Kirban FPR, MAC CAI, Pro M 75MM MAF, BBK 75MM EGR and TB, MSD 6AL2 (will install once I figure out where I want to mount it - inside most likely, but requires extending wires, MSD coil, MAC LT Headers, Prochamber and 40 series Flowmasters
Thanks
sparepartracer
  • Sep 28, 2009
I think a good start point would be about 42psi with vaccume line off on the fuel.Then about 10 or 12 degrees base advance until broke in.Then pull it up for desired setting.Would love to hear how it turns out.
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 29, 2009
  • Sep 29, 2009
Agree about the timing but 30lb injectors are rather big for that H/C/I combo. I'd suggest using the stock 39psi with vacuum off the regulator and have the whole combo properly tuned on the dyno with either a programmeable tuner or a custom chip to get the best results.
It's a well thought-out combo and with a good tune it should rip on the dyno.
L
Limp Fox
31
Newmanstown PA
Sep 29, 2009
  • Sep 29, 2009
unless any one chimes in I will start out with the numbers your provided. Thanks for the response.
L
Limp Fox
31
Newmanstown PA
Sep 29, 2009
  • Sep 29, 2009
I know a lot of ppl think 30# injectors are over kill, but there is a lot of people running them with no issues. I just figured it's better to have bigger injectors that are not running close to the max independence. Plus it helps if I had nitrous later on or what have you.
88-378
14
Alpharetta, GA
Sep 29, 2009
  • Sep 29, 2009
those injectors are fine. You really only want to run an injector at about 85% capacity.
lincoln+ford
195
  • Sep 29, 2009
Nitrous?Maybe if you only ran a dry kit but why would you wanna do that.
L
Limp Fox
31
Newmanstown PA
Sep 29, 2009
  • Sep 29, 2009
No plans to do it, just saying. Most likely I will go with a SC and have to bump up to 40#'s in a yr or two any how. Depends where I'm at. My job like every one else's is not guaranteed. Obami cut to much Military funding and I have one pay left till I got to go out in the civi World. Any time I can pass on Bami-bash I will.
Thanks for your response and thanks 88-378 for making that comment. Most people really feel 30#'s are over kill.
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 29, 2009
  • Sep 29, 2009
Those 30lb'ers will be running at a lot less than that, which is fine. It's better to err on being slightly too big than too small. I don't know if the engine computer will be able to reduce the duty cycle far enough to prevent a rich condition, and that's why I suggested a tune to make sure.
L
Limp Fox
31
Newmanstown PA
Sep 29, 2009
#10
  • Sep 29, 2009
  • #10
Where do you suggest going? I won't go to SGS since I feel I got ripped and the head shop they used rip me has well.
sparepartracer
#11
  • Sep 30, 2009
  • #11
Did you ever get the car running ???
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
SOLD 1993 Mustang LX Notchback- 347 Stroker
  • Bzammitt
  • Jun 19, 2021
6K
Fox Body Mustangs For Sale (1979-93) Jul 10, 2021
Bzammitt
Help me price my car to sell
  • Bkernan24
  • Oct 13, 2020
  • What is it Worth?!?!?
2K
What is it Worth?!?!? Oct 15, 2020
Bkernan24
SOLD For Sale 92 Mustang Notchback Complete Rebuild in 2019
  • pearlnotchback
  • Jun 21, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 24, 2021
Steel1
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
