Where to Buy '72 Steering Coupler
  • Thread starter Thread starter Stanger007
  • Start date Start date Nov 26, 2006
1 of 2 Next Last
Stanger007
2,015
Baton Rouge, LA
Nov 26, 2006
  • Nov 26, 2006
View attachment 421640​
Does anyone know where I can buy the rubber and metal pieces of the steering coupler?
I'm trying to decide if it's cheaper to pay to have the pins machined off so that I can install a poly rag joint with four bolts or if it's cheaper just to buy a whole new assembly since mine is pretty nasty.
I've got a few parts catalogs sitting here but could not find the metal pieces of the coupler for sale - does anyone sell these?
Thanks,
Wes
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Nov 26, 2006
  • Nov 26, 2006
I f u have an NPD catalogue, look on page 68. They have a replacement style coupler for $68.95 or just the insulator for $9.95. Thay also have concours mounting kits. If you don't have the catalogue, I think u can download it in PDF format on their website.
Stanger007
2,015
Baton Rouge, LA
Nov 26, 2006
  • Nov 26, 2006
mustangdave said:
I f u have an NPD catalogue, look on page 68. They have a replacement style coupler for $68.95.
I'll have to give them a call to see if that's one half of the joint or both halves. Looking at their picture it seems to only be one half of it?
Wes
jes72mustang
224
S. Central PA
Nov 26, 2006
  • Nov 26, 2006
Do you only need the rubber rag joint? or do you need the metal peices? from the picture it just looks like the ring is torn and the metal is ok. if that is that case any mustang supplier should have the rag joint (ring) for less than $10 depending if you go with rubber or eurothane (sp?).
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Nov 26, 2006
  • Nov 26, 2006
I think he doesn't want to have to drill out the pins or pay a shop to do it.
Stanger007
2,015
Baton Rouge, LA
Nov 26, 2006
  • Nov 26, 2006
That is correct - I was curious to see if it was cheaper to just buy a whole new assembly vs the rag joint and bolts + machine shop costs.
I've got an e-mail into NPD to see if their assembly is both halves.
If not I'll bring it by a machine shop this week... the Mach has been down for a few weeks waiting on this, I'm itchin' to drive it again.
Wes
jes72mustang
224
S. Central PA
Nov 27, 2006
  • Nov 27, 2006
Now I am curious. I am going to have to re-read the instructions that came with my replacement rag joint. I don't recall them saying anything about needing to press or drill anything out.
Stanger007
2,015
Baton Rouge, LA
Nov 27, 2006
  • Nov 27, 2006
Can you post up a picture of the directions? All the kits w/ the nuts and bolts look to be made from the same manufacturer.
I'm waiting on my rag joint to come in before I send everything off to be machined - don't want them to take too much off.
Wes
jes72mustang
224
S. Central PA
Nov 27, 2006
  • Nov 27, 2006
I will try to remember to do that tonight.
Stanger007
2,015
Baton Rouge, LA
Nov 27, 2006
#10
  • Nov 27, 2006
  • #10
Thanks man I appreciate it!
jes72mustang
224
S. Central PA
Nov 30, 2006
#11
  • Nov 30, 2006
  • #11
Sorry I have not gotten the direction up yet. everytime I remeber I am either in the middle of something else or not at home. I will try to rememer to do it this after noon, especially since I may be replacing my rag joint this weekend.
Writting note to myself.
Stanger007
2,015
Baton Rouge, LA
Nov 30, 2006
#12
  • Nov 30, 2006
  • #12
Not a problem, I owe a picture to a thread in the 94-95 forum but it's been raining here so dang much that I can't crawl under the car to get the pic they need.
I went ahead and ordered the rag joint kit from CJ Pony Parts - waiting on the machining till I get the instructions though - don't want to go too big on the machining.
Thanks man,
Wes
jes72mustang
224
S. Central PA
Nov 30, 2006
#13
  • Nov 30, 2006
  • #13
The instructions are not very good, unless I am missing part of them, but the way it looks is that is all just bolts on. no mention of machining needed.
I also have an article from the August 2004 Mustang Monthly, How to: Replace a Rag Joint. I can Scan the article and email you if you want.
But the jist of it is this:
it does look like you grind off the the mushroomed heads of the tang and then drive them out with a hammer and punch. then the replacement is bolted on. So I really don't see that you would need a machine shop to do any of this repair unles you dont have a grinder.
Let me know if you want me to scan the article.
Stanger007
2,015
Baton Rouge, LA
Nov 30, 2006
#14
  • Nov 30, 2006
  • #14
I bet I've got that issue of MM I'll go check.
Thanks for the tips - I don't have a grinder but would love an excuse to buy one... looks like this is it.
I'll post up how it goes, you do the same if you can.
Wes
Stanger007
2,015
Baton Rouge, LA
Nov 30, 2006
#15
  • Nov 30, 2006
  • #15
Boy it's amazing what the right tools will do.
I bought a grinder from Sears tonite and had all four pins out in about 15 minutes.
Here's how I did it...
Grind down the "mushroom" part of the pin till...
...till you can see the outline of the pin...
...then drive out the pins w/ a punch...
...wash rinse and repeat three more times.
F
ForceFed70
4,818
BC Canada
Nov 30, 2006
#16
  • Nov 30, 2006
  • #16
Sweet! I'll be doing the same thing in a couple of weeks. Thanks for the pics.
jes72mustang
224
S. Central PA
Dec 1, 2006
#17
  • Dec 1, 2006
  • #17
Did you have the article.
Glad you were able to get it going, I hope to start the same operation later today.
Stanger007
2,015
Baton Rouge, LA
Dec 1, 2006
#18
  • Dec 1, 2006
  • #18
I couldn't find that issue of the MM mag - I was missing a few around that time... must have loaned them out.
Let me know how your install goes... I'm waiting on my rag joint to arrive before I can put it all back together.
Wes
jes72mustang
224
S. Central PA
Dec 2, 2006
#19
  • Dec 2, 2006
  • #19
Stanger,
I got my new rag joint and power steering box back into the car this afternoon. The install was pretty straight forward. the most difficult part was lifting the power steering box up and holding it in place while starting the bolts. I think I will be able to install my headers and finish re0installing the power steering pump and hoses tomorrow.
While I had the power steering pump off I cleaned it good and repainted it so it meeds some extra time to dry. PLus it is going to be easier to get the header in without the hoses and pump in the way.
BTW, how hard of a time did you have driving those studs out once you ground the heads off? Mine were pretty tough, I tried with the puch and 10oz ball peen hammer and got nowhere. Finally I traded the ball peen for the 3 pounder, it still took a good effort with that but they fianally came loose. I would have bothered except that I needed those little metal plates.
Stanger007
2,015
Baton Rouge, LA
Dec 5, 2006
#20
  • Dec 5, 2006
  • #20
Mine drove out fairly easy - I used my smaller ball peen and a punch - took about two good wacks to knock them loose - I had the joint clamped down in a bench vise.
I got my rag joint in today and mounted everything up in the car - all went together well except for the new pitman arm. I've got about five good turns on the nut that holds it on and it's getting tight... don't want to end up messing up the seals inside the steering gear but I don't see any other way to get it on unless I figure out a way to press it on and then put the nut on?
Did you have to mess with the pitman arm any?
It started getting cold so I gave up for the night. After I get the pitman arm figured out I've got to connect up the P/S hoses and fill/bleed the system and I'll be good to go.
Can't wait to start daily driving the Mach again!
Wes
1 of 2 Next Last
Suspension Electric Steering rack??
  • Slowpony98
  • Nov 11, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Nov 15, 2026
KRUISR
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
