Where to Buy '72 Steering Coupler
Stanger007
2,015
Baton Rouge, LA
Does anyone know where I can buy the rubber and metal pieces of the steering coupler?
I'm trying to decide if it's cheaper to pay to have the pins machined off so that I can install a poly rag joint with four bolts or if it's cheaper just to buy a whole new assembly since mine is pretty nasty.
I've got a few parts catalogs sitting here but could not find the metal pieces of the coupler for sale - does anyone sell these?
Thanks,
Wes
I f u have an NPD catalogue, look on page 68. They have a replacement style coupler for $68.95 or just the insulator for $9.95. Thay also have concours mounting kits. If you don't have the catalogue, I think u can download it in PDF format on their website.
Do you only need the rubber rag joint? or do you need the metal peices? from the picture it just looks like the ring is torn and the metal is ok. if that is that case any mustang supplier should have the rag joint (ring) for less than $10 depending if you go with rubber or eurothane (sp?).
I think he doesn't want to have to drill out the pins or pay a shop to do it.
That is correct - I was curious to see if it was cheaper to just buy a whole new assembly vs the rag joint and bolts + machine shop costs.
I've got an e-mail into NPD to see if their assembly is both halves.
If not I'll bring it by a machine shop this week... the Mach has been down for a few weeks waiting on this, I'm itchin' to drive it again.
Wes
Can you post up a picture of the directions? All the kits w/ the nuts and bolts look to be made from the same manufacturer.
I'm waiting on my rag joint to come in before I send everything off to be machined - don't want them to take too much off.
Wes
Sorry I have not gotten the direction up yet. everytime I remeber I am either in the middle of something else or not at home. I will try to rememer to do it this after noon, especially since I may be replacing my rag joint this weekend.
Writting note to myself.
Not a problem, I owe a picture to a thread in the 94-95 forum but it's been raining here so dang much that I can't crawl under the car to get the pic they need.
I went ahead and ordered the rag joint kit from CJ Pony Parts - waiting on the machining till I get the instructions though - don't want to go too big on the machining.
Thanks man,
Wes
The instructions are not very good, unless I am missing part of them, but the way it looks is that is all just bolts on. no mention of machining needed.
I also have an article from the August 2004 Mustang Monthly, How to: Replace a Rag Joint. I can Scan the article and email you if you want.
But the jist of it is this:
it does look like you grind off the the mushroomed heads of the tang and then drive them out with a hammer and punch. then the replacement is bolted on. So I really don't see that you would need a machine shop to do any of this repair unles you dont have a grinder.
Let me know if you want me to scan the article.
Stanger,
I got my new rag joint and power steering box back into the car this afternoon. The install was pretty straight forward. the most difficult part was lifting the power steering box up and holding it in place while starting the bolts. I think I will be able to install my headers and finish re0installing the power steering pump and hoses tomorrow.
While I had the power steering pump off I cleaned it good and repainted it so it meeds some extra time to dry. PLus it is going to be easier to get the header in without the hoses and pump in the way.
BTW, how hard of a time did you have driving those studs out once you ground the heads off? Mine were pretty tough, I tried with the puch and 10oz ball peen hammer and got nowhere. Finally I traded the ball peen for the 3 pounder, it still took a good effort with that but they fianally came loose. I would have bothered except that I needed those little metal plates.
Mine drove out fairly easy - I used my smaller ball peen and a punch - took about two good wacks to knock them loose - I had the joint clamped down in a bench vise.
I got my rag joint in today and mounted everything up in the car - all went together well except for the new pitman arm. I've got about five good turns on the nut that holds it on and it's getting tight... don't want to end up messing up the seals inside the steering gear but I don't see any other way to get it on unless I figure out a way to press it on and then put the nut on?
Did you have to mess with the pitman arm any?
It started getting cold so I gave up for the night. After I get the pitman arm figured out I've got to connect up the P/S hoses and fill/bleed the system and I'll be good to go.
Can't wait to start daily driving the Mach again! :)
Wes
