Im looking to buy a J4J1 cobra ecu? where would i find one? or does anyone have the p/n for the autozone or advance cobra computer? they list all of the 94-95 gt and cobra computers together buy p/n not computer code. thanks!
Well, it depends on what you think sucks i suppose. they dont have the greatest timing and fuel tables, but they are a very realiable and cheap way to run 24lb injectors on a modified engine until a tune can be afforded in which case the problems with the j4j1 processing can be eliminated. anyone know where to buy one? the original question? thanksblk9450 said:why do you want one, dont they suck?
No, a new computer from advance auto parts is 109 dollars. Any decent maf will be at least 2-300 dollars. And it still wont function correctly unless a chip is burnt. it may seem to run ok, but any meter that tricks the computer into running larger injectors isnt imo ok. the cobra computer is excellent, especially when tuned correctly with a chip on a dyno. ford was trying to save transmissions and such when they designed it, so they could warranty there cars. at any rate, this really isnt the discussion. im just trying to buy one, my mind is made upblk9450 said:maf would be cheaper, and a better end result imho
final5-0 said:There are some folk that say they don't suck.
http://forums.stangnet.com/showthread.php?t=586904
Grady
84convertablegt said:Im looking to buy a J4J1 cobra ecu? where would i find one? or does anyone have the p/n for the autozone or advance cobra computer? they list all of the 94-95 gt and cobra computers together buy p/n not computer code. thanks!
so why dont you go to the store and buy one for 109 instead of posting here??84convertablegt said:No, a new computer from advance auto parts is 109 dollars. Any decent maf will be at least 2-300 dollars. And it still wont function correctly unless a chip is burnt. it may seem to run ok, but any meter that tricks the computer into running larger injectors isnt imo ok. the cobra computer is excellent, especially when tuned correctly with a chip on a dyno. ford was trying to save transmissions and such when they designed it, so they could warranty there cars. at any rate, this really isnt the discussion. im just trying to buy one, my mind is made up![]()
there was a kit for a while painless made to use a a9l in a 94-95.final5-0 said:Have you looked on the Corral parts forum or asked those guys in the 94-95 forum?
I've seen quite a few threads where Cobra peeps went with the A9L retro-fit.
Grady
blk9450 said:haha thats only you saying cobra computers dont suck....
blk9450 said:so why dont you go to the store and buy one for 109 instead of posting here??
i see you said advanced sells the gt and cobra as one, but you could order it and look at it b4 you buy it. plus, if you get the correct maf, you DONT need a chip, you can get a c&l for ~100 on ebay, and of course it tricks the ecm into thinking its something its not. the maf can only output say 0-5 volts, how else do oyu fit the spectrum of the air flow data; you have to squish/stretch that data over the specified field. i feel like im going in circles. you say the cobra computer is great when tuned on a dyno, thats proably because they swap the gt maps in.
and fox guys are
. They are ok stock not great, not totaly junk but with some work (when you would get some kind of tune) they will run just as well as a tuned A9, and sometimes work better due to the load based tables. IF your going to get a tune why swap to something else for its ability to run alittle better maybe.
