Where to get wiring with connectors?
williet57
14
Anyone know where I can buy a wiring harness that runs from the regulator to the distributor and a harness that goes from the main harness to to the coil?It is for a 84 5.0l. I have tried all the yards around Columbus Ohio and no one has any models that would work.All the major Fox parts sellers do not stock any thing like this. I might havt to eliminate the connectors and wire direct but do not want to do this. Any idaes where to get these harnesses?
Did you try frank n stangs in Franklin Indiana?
Frank
Frank-n-Stangs
Franklin, Indiana 46131
317/371-5783
Wiring connectors are availabe from RJM Injection Tech » Pigtails:
You will need the pins if you aren't going to replace the actual wiring. They have the correct pins & crimper tool.
NAPA Auto Parts also carries some pigtail wiring assemblies.
