where to jack up motor from??
  • Thread starter Thread starter DMAN302
  • Start date Start date Aug 17, 2005
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 17, 2005
  • Aug 17, 2005
Hey guys, I will be installing new motor mounts this weekend (convertable) and can't remember for the life of me where I did jack up the motor from when I did my LT install some yrs back. Shoud I with a say 12 inch 2x4 jack it up from under the frot sump..or rear? The rear is not flat (stock style replacement pan) and has the oil drain plug of course dead center, while the front sump seems more jack freindly. I unfortunately do not have access to a picker, and will be raising it via jack/wood block. Let me know guys...Thanks,
Derek.
marine_2003
427
Lake County, FL
Aug 17, 2005
  • Aug 17, 2005
I just recently changed mine out and i put a 2x4 on the jack and jacked it up centered on the balancer. Just make sure your centered and carefully jack it up.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 17, 2005
  • Aug 17, 2005
I don't like the idea of jacking on the balancer..just don't see that as good for the bearings..thanks for the time though.
281pony
2,681
Oly, WA
Aug 17, 2005
  • Aug 17, 2005
id go from the front of the pan personally.
jacking it up from the balancer? thats putting stress right on the end of the crank also.
P
pconway
72
wtby, ct
Aug 17, 2005
  • Aug 17, 2005
Dont do it on the pan. This mechanic did that to my dads truck and it crack dented and now my dad cant change his oil unless he puts a new oil pan on it.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 17, 2005
  • Aug 17, 2005
You can bet money if I used a mechanic, and this occured I'd have left that garage with a new pan installed, or a mechanics toolbox full of his tools. Anyhow I appreciate the input..I am leaning towards the front sump..I just want to be sure the front sump can handle the weight of the the engine..thanks guys.
5.0vert
49
bethesda md
Aug 17, 2005
  • Aug 17, 2005
i jacked it up form the pan usin a peice of wood cant remeber if it was a 2x4 not actualy it wwas we used a peice of my friends fence lol and it worked fine pan is stillin the car undented
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 17, 2005
  • Aug 17, 2005
Question was...which sump..front or rear..is the oil pump pick up in danger with either one...just want to ensure I'm approaching it properly.
5.0vert
49
bethesda md
Aug 17, 2005
  • Aug 17, 2005
im almost positive we id it in the rear im like 99,9999999999% sure it was the rear sump
Modular2v
3,222
23
99
oklahoma
Aug 17, 2005
#10
  • Aug 17, 2005
  • #10
put the jack on the very front of the bellousing and jack it up
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 18, 2005
#11
  • Aug 18, 2005
  • #11
That's a great idea..same one I rec'd from another very reliable source (older source). I wasn't sure if the bell housing could handle the weight, but I thought I could have a secondary jack under the sump to take off some of the force. The engine is new, and as a freind pointed out to me..jacking primarily on the pan could damage the oil pan gasket, which has already been kind of a situation I just corrected. So the bell housing sounds great..thanks.
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Aug 18, 2005
#12
  • Aug 18, 2005
  • #12
I used 3 jacks...bellhousing, rear sump and the frontmost lip of the oilpan. That distributes the weight very evenly.
The Shape
2,224
East ARKANSAS Delta
Aug 18, 2005
#13
  • Aug 18, 2005
  • #13
That's a good idea Pete I just used a small block of wood under my rear sump and have a nice dent in the pan to prove it . If I ever have to do it without a lift again I paln to do like you are sugesting using more than one jack to support the weight. Hindsight is 20/20
Fishhawk
281
Michigan City, Indiana
Aug 18, 2005
#14
  • Aug 18, 2005
  • #14
DMAN - Make sure you do a follow up on this. I'm thinking of putting in new mounts myself and would like to know how it went.
PS, I have always heard of guys using the pan, but I have to admit I've never felt comfortable with it. Just try to distribute the weight as much as possible.
crazypete
Oct 22, 2004
930
Arlington, MA
Aug 18, 2005
#15
  • Aug 18, 2005
  • #15
Those sheetmetal pans are surprisingly strong. The pan on the aod, just a semi square pressed metal pan, supports that 200 pound monster when it's sitting on the ground. If you dont present any sharp edges, the oilpan will hold up just fine. I like the bellhousing support since if the jacks slip, the motor wont fall on your head.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 18, 2005
#16
  • Aug 18, 2005
  • #16
OK when jacking up by the front lip of the bell housing will a block of wood be required, or just the jack face itself...dumb questions but might as well get all the info I can.
crazypete
Oct 22, 2004
930
Arlington, MA
Aug 18, 2005
#17
  • Aug 18, 2005
  • #17
Cusion everywhere. You almost never jack without wood (huh huh) anywhere. That bellhousing is aluminum. You need all the pressure distribution you can get.
Fishhawk
281
Aug 18, 2005
#18
  • Aug 18, 2005
  • #18
I would say use wood. As soft as possible.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 18, 2005
#19
  • Aug 18, 2005
  • #19
Ok so I will raise the engine from the front lip of the bell housing..via jack and wooden block (2x4)..then once height is reached..will place jack on front sump (also with wood block) and jack up until SOME resistance is felt in the jack. Thanks guys I don't remember my method when I installed my LT's but I'm sure this one is a better approach.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
M
  • mnky99
  • Sep 5, 2025
mnky99
M
