Where to mount line lock switch??
  • Thread starter Thread starter afterglow
  • Start date Start date Apr 8, 2007
A
afterglow
89
  • Apr 8, 2007
Where do you guys mount your line lock switch?? I have a 69 Mach 1, stock automatic shifter, no console (although I do have a humphugger). Where should I mount my line lock switch??
I could mount it on the console but then it doesn't become removable anymore. Any suggestions???
iskwezm
4,159
20
79
Rowland Heights,California
Apr 8, 2007
  • Apr 8, 2007
i have mine mouted to my turn signal switch,easy to reach with a finger and still hold the wheel with both hands
MustangMatt1966
1,004
Orlando Fl.
Apr 8, 2007
  • Apr 8, 2007
i have the shift knob with the line lock switch on it...it works great
BullittStangV8
1,104
NJ
Apr 8, 2007
  • Apr 8, 2007
Which line lock's did you guys go with?
shhak
109
  • Apr 8, 2007
I just had a SLP line lock installed on my 03 cobra. They put a switch down next to my 12v power outlet by the shifter. The switch just activates the actual line lock control. The actual control is the "flash to pass" switch (pulling the turn signal lever towards you holds the breaks) when the switch by the 12v power outlet is turned off, the "flash to pass" works like it's supposed to.
A
afterglow
89
  • Apr 8, 2007
This might be the way to go. Any pics??
A
afterglow
89
  • Apr 9, 2007
Another option I was toying around with is to replace just the handle of my (stock) setup with something from Hurst or B&M that has a button. Something like this:
or
Will this work?? Would anybody know what size thread the stock handle uses?? Or do I need to get my butt over to the shop and check it for myself??
T
tylerrocks
514
Big Spring, TX
Apr 9, 2007
  • Apr 9, 2007
Thats friggen awesome. Terminators rule.
classic boost
709
canton, oh
Apr 9, 2007
  • Apr 9, 2007
i put mine on a dimmer switch, a few inches away from the stock one on the floor board.
shhak
109
#10
  • Apr 9, 2007
  • #10
That's another good idea. I had mine done the way I did because I didn't want the inside of my car looking like a race car. Trying to keep it as stock looking as possible.
iskwezm
4,159
20
79
Apr 9, 2007
#11
  • Apr 9, 2007
  • #11
I'll try to get some for ya.Its wired with my 2 step, so it hold the brakes and the rev limiter at about 4500 for nice launch
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
Issue with trans mount not lining up with crossmember slots
  • Bbaker2317
  • Mar 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2025
limp
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
