where to set fuel press
BadAndy
766
Ohio
I have a 5.0 stang with edle heads- cobra intake -headers- and stock cam, larger mass air and t-b, it also has 19lb-inj,s with a 255 intank pump-- what should i set my fuel press at???????/
thanks
35 PSI would be way too lean for that set up, especially with 19lb injectors- you need 24's. I would start at 38-40. Unfortunately, a wideband would be the only way to know for sure. Alot of it depends on the motor. You will have to experiment a bit.
when i adjust i remove the vacuum line at the adj. fuel pressure regulator and plug the vacuum line with my finger or a small screw and adjust to 38-40 and then reinsert vacuum line....done.its easy for me because i have a fuel pressure guage permanetly mounted under my hood see pic...
