Which alternator to use?
wickedmach1
376
Austin, TX
I will be installing a 393 stroker in my 1970 Mach 1. I have a mechanical water pump and fule pump. I have dual electric radiator fans. I plan on installing a good stereo system but nothing too crazy. I was wondering which alternator to use. I was thinking about a 130amp unit. Which brands have you guys used and what amp alternator would you use for this combo? Thanks.
The 3g swap is so common, just search the classic forum and you will find a ton of info on it. You can get them out of V6 late model Mustangs up to I think 2004 and you can get them on the late 90s Taurus as well. They mount just like a stock 1g does. You may need to helicoil one bolt hole if you don't want to use a bolt and a nut to holt it on. Thats what I did on mine.
