Which Automatic Transmission?
93gtmustang
515
43
49
Could you please reccomend a transmission for me?
I mainly use the car for bracket drag racing.
The car is driven back forth to the track, 1/2 hour each way.
I'm looking for an automatic that I can shift at the track and also has overdrive for the highway.
I was looking at PA Performance, TCI, and B&M.
My motor has 345 horse power at the flywheel.
Could you please include a parts list of everything that is needed for the install?
Below is my current car set-up.
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / Racing Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
