Which Balancer should I use? 1991 5.0
BLK3DGT
47
I'm rebuilding the bottom end of my 5.0 The crank is being polished and balanced and I have a new SFI Billet steel 50 oz flywheel ready to be bolted on. The crankshaft damper is original and is in bad shape, 125,000 + MILES. 1991 Mustang GT. Which crankshaft damper do you 5.0er's recommend?
I'm looking at the High performance Ford balancer 50 oz. The car is going to see more street time than track.
New Probe 10:1 pistons .030 over, with clevitte bearings, rings, melling high volume oil pump and a Trick Flow upper engine kit. Also did AOD swap to t5 last week end. Project still going on:SNSign:
Also thinking of installing the King Cobra clutch from Ford for now, until I'm ready to start racing car at the track. What other clutches would you recommend?
Any suggestions will be appreciated.
Thanks,
BLK3DGT
