Which block?
Grn92LX said:
Shouldn't take 600hp to run low 10's if you're hooking. dart block is the way to go if you have the cash and wanna do it the right way.
and if you have a decently flat torq curve. alot of these imports and such need like 800hp to run 11's becouse they only have like 1500rpm of usable power
well, anyways, if times and cheap are your goal I would go with a newer 351 block out of like an econoline van or something. biuld that bitch and spray it :nice:
Daggar said:
Ford Sportsman is a joke. It's a really expensive stock block in terms of HP capability.
:stupid: I can't believe they wanna charge $900 for a basically stock block...strengthened main caps and and main webbing my a$$
wanna make a $900 (or $1200 for that matter) aftermarket block that sells? nodular four bolt mains on 2,3,and 4, main webbing that doesn't taper off to 0.100", and walls thick enough to bore out at least 0.060" without worrying about core shift-oh! and no need for finish honing of the lifter bores, or main bores.
basically a Boss block with thicker cylinder walls, and main webbing...
edit: I know, I know, the Dart is only $1800 from some places, but then you still have to have the lifter bores finished, and honestly some people are only looking for an interim block, one that won't split @ 450hp...I don't need a block that can support 1200+hp...650 would be right up my alley though
Don't we all... There's really no in between. It's either a stocker or a Dart.
If you want 600rwhp and 10's from a 302 based block, I surely hope $1,800 for a good block should not be a problem. You'll see what I'm talking about when you start breaking major components.
:stupid: Pay = PLay :nono: exeptions
if i have to ill break the pic out..
trust me, i'm very aware of the consequences of putting a stock block through the rigors of high hp...i don't need to see any pix to reitterrate that truth. just kinda irritating that Ford never saw fit to produce a more rigid four bolt block in higher numbers than were available...
i know that if i want stratospheric hp numbers, I will be req'd to save up the green to purchase a Dart or WP block...such is life
...honestly, you're still pushing it, the Mexican block is usually better than a roller block, but it's still a 2 bolt, and it's still got fairly thin webbing...it's (supposedly) cast from a higher nickle content alloy, but you'll still be limited...
and if you were to run a Mexican block, you'd either have to run a flat tappet cam, or to use a roller, you'd have to run a small base cirlce cam with stock lifters, or get the expensive locking bar lifters with a stock style roller cam
