Which c/c plates to buy?
jmd2914
937
Napa, California
My strut mounts are shot and when something dies.....upgrade!! i was deciding between the frpp c/c plates and the bbk c/c plates. anyone have any good/bad experiances with both of these? how hard is the install? just take out the old ones and swap in the new plates?
Avoid CC plates made from aluminum, they aren't as strong as steel ones. Also avoid CC plates that use a rubber bushing for the strut mount - the rubber deflects under extreme loads & changes the front end geometery. A good CC plate should be made of steel and have a spherical bearing at the top.
I have Steeda CC plates and they meet the requirements.
jmd2914 said:
Ill probably end up buying those, what makes them so good? opposed to other brands?
MM C/C plates! I have them and they're top notch quality.
They have a 4-bolt C/C plate .... and most others are 3-bolt. However, I believe you Fox guys use 3-bolt plates only. Someone correct me if I'm wrong.
They're made of a sturdy alloy steel & are powder coated. Not some cheap aluminum crap. They also have the spherical bearing mentioned earlier, rather than a rubber bushing.
I don't know if all cars are the same ..... but mine came with aftermarket bumpstops, strut spacers, ties for your dust boots, and very simple instructions.
The best (cheapest) place to get them for me was from Josh over at www.stangsuspension.com.
EDIT: BTW, they offer a discount for those in the military. Also, check out ponyboy's link to get that kind of discount.
jmd2914 said:
alright I'm goin with MM plates. how hard is the install? just take out my old strut mounts bolt in the cc plates then go get an alignment?
just follow the instructions.. it's not that hard. Get an alignment when you get them on.
alright. im also planning on getting new rims/tires and rear lower control arms. should i get all the work done then do the c/c last then get it aligned? or does the order matter? as long as i do the alignment after the cc plates
the wheels and rear control arms won't matter in the front end alignment. But if you need new struts, tie rod ends, ball joints, or any other front end suspension part, it may be a good time to R&R it while it's apart.
