- Mar 30, 2005
- 388
- 0
- 0
I had the same experience with an Accel Super Coil...took it back,bought the Moroso coil and no more EMI,(electromagnetic interferance) noise.Guyfoxbody said:I have spoken with several reputable shops about coils. I had the MSD TFI which I sent back to Summit cause it hummed and buzzed me out of the car. Unless your running an H/C/I and a full ignition set up it's not worth it to just replace the coil. The stock coil is fine.
When I get to an HCI setup, I don't think I will be able to hear the hum, so I will try again when I get to that level.
8950HO said:I had the same experience with an Accel Super Coil...took it back,bought the Moroso coil and no more EMI,(electromagnetic interferance) noise.
From what I`ve read,the output of the stock coil starts dropping off as the rpm`s go up.
Same here!!ALMOST STOCK said:Crane PS 91 here!
No problems and/or no issues in over 4 yrs![]()
I have the MSD coil and it certainly makes noise - I've been told that if I switch to MSD 8.5mm wires, the noise will go away. I still have yet to test that theory.Curse said:My MSD coil doesn't make any noiseI have used both the blaster SS coil and the TFI coil
I don't see how, but who knows89roadster said:I have the MSD coil and it certainly makes noise - I've been told that if I switch to MSD 8.5mm wires, the noise will go away. I still have yet to test that theory.
, maybe it is the way you guys are wiring up your coil. I have the advantage of my dad being an MSD tech, so he has me do a lot of extra stuff that is not mentioned in the instructions.
