WHICH direction, URGENT
  • Thread starter Thread starter DouglasOhio
  • Start date Start date May 12, 2005
D
DouglasOhio
116
Canton Ohio
May 12, 2005
  • May 12, 2005
ok im replacing my harmonic balancer as i type this, but i cant find anything about it in my book and i need to know if the balancer bolt has regular or opposite threads.
So if anyone could tell me if clockwise is loose or if counterclockwise is loose, that would be awesome.
SEE
my last post here to answer my next question please....
thanks in advance
Vipersix
434
Clarksville, TN
May 12, 2005
  • May 12, 2005
The balancer bolt? You mean the big one in the middle that connects it to the crankshaft? That is a normal clockwise tighten/counterclockwise loosen bolt.
D
DouglasOhio
116
Canton Ohio
May 12, 2005
  • May 12, 2005
sweet, thanks got the old balancer off
NOW i have a new question, i saw on summits directions they recommend boiling the new balancer in water to make it easier to install. Is this a good idea? or will i be able to get it on (without installation tool tho...) without boiling it?
Vipersix
434
Clarksville, TN
May 12, 2005
  • May 12, 2005
The purpose of boiling it is to make it expand (heated materials expand) enough to slip on without the need of an installer tool. I'm not real sure that boiling will bring the temp high enough to make much of a difference though. I would highly recommend finding a tool or renting one so it'll go on there evenly. If you bang it on with a hammer or other such item you can warp the balancer and cause all kinds of havoc on your engine at RPM.
HISSIN50
34
129
May 12, 2005
  • May 12, 2005
Agreed with VS - some folks toss the balancer in the oven instead - I am not a fan of that either. but if it wont go on any other way.........
the install tool is a must, IMHO. it kept me from having to cook my new balancer.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 14, 2025
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
