which distributor?
  • Thread starter Thread starter sweet03cobra
  • Start date Start date Sep 27, 2006
sweet03cobra
46
Anchorage, Alaska
Sep 27, 2006
  • Sep 27, 2006
I have a stock mustang engine (1991) that I went through and was looking at possibly getting a new aftermarket distributor. If I go with an MSD, what part # would I need. I did a search through summit and they gave me like 10. Any help would be appreciated. Or is there a better distributor out there for the price, maybe crane or something? Thanks
gcwh02
515
pottstown, PA
Sep 27, 2006
  • Sep 27, 2006
stock one will do just fine for you, id keep yours if nothings wrong with it. I hear that stock is just about as good anyway. Just get a better cap/rotor/wires.
sweet03cobra
46
Anchorage, Alaska
Sep 27, 2006
  • Sep 27, 2006
good info, thanks
bullitstang1313
713
Indianapolis / Columbus, Indiana
Sep 27, 2006
  • Sep 27, 2006
You won't really need to upgrade the distributor / ignition system unless you started modifying everything else. If you want to go with an MSD the part number is MSD-8456, this is for fuel injected 5.0L engines with hydraulic roller cams.
sweet03cobra
46
Anchorage, Alaska
Sep 28, 2006
  • Sep 28, 2006
Now any aftermarket cams I buy like the lunatis or the say a trick flow or TSF will all be a hydraulic roller cam right? Now I plan on running a 150 shot, is there any part of the ignition system I should upgrade besides wires and colder plugs? Thanks for the part #.
bullitstang1313
713
Sep 28, 2006
  • Sep 28, 2006
You might want to get an ignition box with a timing retard/advance built into it. I'm not exactly sure how these work, but you will want the timing to be different when you use nitrous than when you are running just motor. You might look at a MSD 6AL or something like that.
gcwh02
515
pottstown, PA
Sep 28, 2006
  • Sep 28, 2006
Yea the MSD 6AL is perfect. That comes with a built in rev limiter but you will have to buy the retard/advance module seperate. Might as well spring 45 more bucks for the blaster 2 too
Flavadave4
1,044
21
49
Utica, NY
Sep 28, 2006
  • Sep 28, 2006
I just bought a MSD through Summit, it was cheaper than the stock replacement!!!
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Distributor Interchange List
  • Wayne Waldrep
  • Jun 21, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2026
dan50
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
