Which driveline combo do you think would weigh less???
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Just thinking here. Which do you think would weight less.
An 351 fuel injected setup with Al heads, Cobra intake and all other relataed fuel injectior gizmos with a T-56. No smog pump, A/C or P/S
Or
A 96-98 Cobra Alumunum block/headed 4.6L DOHC with a T-56?? No A/C but P/S would remain to run hydroboosted brakes. Also, would be installed with aftermarket k-member for 4.6L engine
Think it's close enough not to really matter?
I guess you could find the dry weights of the engine combos, and find what each transmission weighs...
T5's weigh around 80lbs I believe...
I'm sure D&D would know the weight of a t56, which would be more...
Some info:
4.6-liter SOHC and DOHC
Aluminum block weight (bare): 86 lbs.
Iron block weight (bare): 154 lbs.
Assembled cylinder head weight: 44 lbs.*
Displacement: 4.6 liters/281 cubic inches
Bore: 3.552 inches
Stroke: 3.543 inches
Bore spacing: 3.937 inches
Main journal dia.: 2.657 inches
Rod journal dia.: 2.086 inches
Rod length: 5.933 inches
Deck height: 8.937 inches
*Assembled 302 iron head weighs approx. 55 lbs.
I know the beefier R302 block, if I recall weighs around 160lbs.
I think the 4.6 DOHC will be lighter:)
