  • 1994 - 1995 Specific Tech
Which gas?
  • Thread starter Thread starter eap95gt
  • Start date Start date Aug 31, 2004
E
eap95gt
65
Rocket City, AL
Aug 31, 2004
  • Aug 31, 2004
I have been told that my 95 5.0 came off the show room floor set up to burn 87 octane gas.
Every time I try to run it, my car pings bad. It has 111K miles with no oil burn or other engine issues.
When I run 91 or better (currently 93 in Alabama), there is no pinging except under load (a/c on) at 4500-5000 rpm.
Which is correct? Can the car be tuned to run 87 or 89 octane without cheating performance?
Eric
GTJake
3,049
Ann Arbor, MI
Aug 31, 2004
  • Aug 31, 2004
Clean the MAF and do an all around tune up. If that doesn't help you may need the higher octane.
Jake
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 31, 2004
  • Aug 31, 2004
Check your timing a may be set to high. It should be a 10* unless it has be advanced to 14* for the extra hp than you must run a higher octane.
HISSIN50
34
129
Aug 31, 2004
  • Aug 31, 2004
dont forget that more compression increases the chance of detonation. if you have a lot of carbon build up in the chambers, your compression can be artificially raised enough to require more octane (slower burning fuel - less volatile).
as for pinging at higher revs, i might also hook up a FP gauge and monitor the pressure at those revs. if you are running low on pressure and thus lean, that does not help.
good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 31, 2004
  • Aug 31, 2004
You have the classic 94-95 pinging. Do a search on the forum on how to get rid of it.
Running 91 octane will make your car slower, and only "hide" the pinging problem.
Scott
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Fox What gas do you run in your foxbody?
  • Mindseye007
  • May 14, 2024
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 19, 2024
Bullitt347
  • dan50
  • Jul 18, 2026
dan50
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
