Which Injectors should I buy?
Looks like I'm going to need a new set of injectors. Balance test flags 3 cylinders in the first pass, then 2 cylinders in the next two tests. Plugs are clean or nearly so on the two worse cylinders. The car was sitting for 8+ years so not surprised that the injectors would be fouled. Which Injectors do you recommend these days. Car is close to stock so 19 pounders are fine.
Thanks!
Bob
Thanks for this.
I like the idea of rebuilt and flow tested OEM. I have ordered a set of rebuilt and matched injectors and will send my originals off once they arrive. Like the idea of having spares for a car of the vintage...
Reactions: gkomo
