which Long Tubes...
  • Thread starter Thread starter SitDown
  • Start date Start date Oct 20, 2004
SitDown
335
Chicagoland
Oct 20, 2004
  • Oct 20, 2004
Im looking for some full length headers for my 331 '65. Id like to go with a 1 3/4 with 3" collectors, but its pretty damn tight so if fitting that is quite the task i may settle with 1 5/8....
WHich out of box headers have you used with your 302's and what are your opinions on the flow,clearence(bellhousing/ground), fit, quality??
im not interested in the Y design ones and they must flow well as ill be making just under 400rw on motor and will see some spray as well. appearence doesnt matter too much. for refrence it is a t5 car and it probably makes a big diff but steering is still undecided so im not sure where this may hurt extra room avail...
anything u guys have to say will help
Thanks
2bav8
2,511
Mesa, AZ
Oct 20, 2004
  • Oct 20, 2004
I've been pretty happy with my Hooker Super Comps.
They have a 1 5/8" primary tube and 3" collectors.
The 1 3/4" headers are a little harder to come by.
SitDown
335
Chicagoland
Oct 20, 2004
  • Oct 20, 2004
yea thats what ive been seeing... any clearence issues with the steering shaft, lakewood or manual equipment?
one2gamble
902
Monterey
Oct 20, 2004
  • Oct 20, 2004
I use the hedman elites and they hang way low in my car
ratio411
3,870
73
109
Pensacola FL
Oct 20, 2004
  • Oct 20, 2004
I have had many sets over the years...
Hedman
Hooker
Flowtech
Blackjack (when they still made car headers)
Cyclone
The "generic" 1 5/8" design of these brands are all nearly identical. The primary and collector flanges are the only difference I have ever found...
They all have crappy paint when new.
They all fit floor shifters, but not column shift.
They all need the power steering drop bracket.
They all need spacers to fit with a C6 tranny.
They all have a couple of header bolt locations that need to be started with the header away from the head a bit. Due to a couple of primary pipes that turn backwards quickly and limit bolt clearance once the headers is against the head.
I have found all have good ground clearance.
I have never had a frame or car clearance issue, except when using a C6... You must use a bare exhaust flange to space the headers away from the heads a bit, along with longer header bolts.
None are compatable with header studs or allen bolts.
They all need some weld boogers cleaned from the primary entries if you want them perfect.
This is my take on the good ol' generic Ford passenger car header. Once you start talking specialized headers and fancy names, then there are surely differences... the last time I checked, Hedman doesn't even make the 'standard' design anymore. They have gone more specific on the applications.
Dave
SitDown
335
Chicagoland
Oct 20, 2004
  • Oct 20, 2004
thanks dave, good information...it seems 1 3/4 are out unless i want to drop a mint
G
gp001
4,401
So. Cal.
Oct 20, 2004
  • Oct 20, 2004
Thanks
The search is your friend
http://forums.stangnet.com/showthread.php?t=494678&highlight=headers
allcarfan
The Answer Man
2,458
North Atlanta
Oct 20, 2004
  • Oct 20, 2004
hooker makes a 1 3/4" headers off the shelf.
I bought mine custom made from a company in Cali. Ran me $740
F
fastback brian
540
So Cal , I.E.
Oct 20, 2004
  • Oct 20, 2004
RCI, Accufab, JBA and a few others have them off the shelf. Just as long as you dont have a highport, TFS R, or yates style head. you should be just fine with the super comps and a good striat through muffler.
SitDown
335
Chicagoland
Oct 21, 2004
#10
  • Oct 21, 2004
  • #10
i didnt notice those on hookers site, ill def have to recheck tho. I run Vic Jrs. likely ill go with hookers as the JBA stuff is a bit pricey for me right now. thanks guys
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
