DO NOT heat the springs. Your car will ride like A$$ (it softens the rate), and if they weren't heated evenly, you could have an uneven drop. I would try removing the isolators, then, if it's not low enough, I would try cutting 1/2 coil at a time until you get what you want. If you cut too much, you could put the isolators back in to regain some height.
