Which one would you buy?
  • Thread starter Thread starter 1Slow90coupe
  • Start date Start date Apr 1, 2006
1Slow90coupe
145
  • Apr 1, 2006
3 Row Copper/Brass Radiator from Advance Auto $160 or so
or
2 Row Aluminum Universal from Summitt $180 or so
Any help appreciated.
What are the advantages/disadvantages to each?
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 1, 2006
  • Apr 1, 2006
3-row.
I don't like universal products. I want my things to fit in OEM.
Plus the 3-row does a good job at keeping my car cool. I used distilled water in my rad so it keeps corrosion and deposits down.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 1, 2006
  • Apr 1, 2006
Get the one from your parts store. Lifetime warranty
P
PRO50SC
1,012
Olney, Maryland
Apr 1, 2006
  • Apr 1, 2006
2 row aluminum will disapate the heat better. I got a direct fit off e-bay for 240 shipped
F
fox_bodies_rule
34
  • Apr 1, 2006
What those guys said, I yanked the FRPP aluminum rad out of mine and put in a NAPA 3 core ...it's made by Molidine and set me back about $135 and is the same size as stock, distilled water and water wetter help as well. The FRPP fit like crap, had an auto trans tank that I didn't need and PLASTIC ends.
bill302
2,131
alabama,gadsden
Apr 1, 2006
  • Apr 1, 2006
advantage $20=$9 handling fee = $29 in your pocket plus its a perfect fit.if your worried about cooling use a 180*thermostat.does the advance radiator have a 1 year or lifetime warranty if i had too i would pay a little extra for a lifetime warranty.
vristang
4,933
101
124
Seattle
Apr 1, 2006
  • Apr 1, 2006
The 3 row from the parts store is a great unit. Depending on your application the 2 row may be sufficient and cheaper. I bring it up because I put a 2 row on my 408w as a quick fix, but it has held up for several months now.
Universal = PITA to install
I don't see a need for Al if the rest of the system is up to par.
jason
SPEEDYLIFSAVR
666
FL,89 LX 5.0
Apr 1, 2006
  • Apr 1, 2006
I got the GoDan HD from Pepboys , that thing cools like nobodys business . Its a 3 core brass radiator .
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 1, 2006
  • Apr 1, 2006
With the 3-core, distilled water/coolant, watter wetter, a new pump, SN95 electric fan and a 180* thermostat, my cooling system works great.
It runs at a constant 188* even on hot humid days inthe summer. In the fall/spring i don't even need to turn the fan on too cool the car. Just driving is enough to keep it cool.
T
TheUser
1,859
Springfield, MO
Apr 1, 2006
#10
  • Apr 1, 2006
  • #10
I got a 2 core OEM replacement for like $117 after taxes at O'Reily's and it does a great job. I too run distilled water/anti-freeze mix to cut down on the corrosion.
I have a stock thermostat, taurus 3.8L V6 electric fan and a DCC control unit and have ZERO cooling problems. This is on my stock 90 LX 5.0, but I believe it work well fine on a mildly modded stang as well.
1Slow90coupe
145
#11
  • Apr 1, 2006
  • #11
Thanks for the info, Looks like most prefer the direct fit 3 row. My car is mildly modified and am just looking for something better than stock.
Anyone know the weight difference between the two?
Once again, Thanks
9
90lxfoxbody
264
#12
  • Apr 1, 2006
  • #12
i got an all aluminum tig welded rad off ebay for $223. looks serious and works great. i use distilled water and a valvoline brand corrosion/rust inhibitor/water pump lubricant with regular antifreeze. i have the black magic #175 and so far the setup has worked great.
just4bob50
504
Pa.
Apr 1, 2006
#13
  • Apr 1, 2006
  • #13
I got a Summit brand direct fit radiator for around250. It fits great and is twice as thick as the stocker. drivers side of the rad. stays so cool you can put the back of your hand on it during normal opperation.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
