I don't have any cooling problems after running the U/D pulley kit.STREETFIGHTER50 said:more q's????
anyone have any cooling charging problems installing these?
also, how about the a/c function? will it still blow cold even at idle?
illwood said:I'm running some ASP pullies from Summit. They're black anodized aluminum and go for ~$94.
Oh, heh, that's just a typo that's a carryover from the ASP website. It's correct in the column listing, but incorrect when you click on the link for them. Part of the givaway is that you can't anodize steel. Black oxide, yes, anodize, no.STREETFIGHTER50 said:I was lookin at Autospecialtie's website & could only see "steel" pulley kits for our '94/'95's. They come in 3 different finishes-nitride, zinc, or black anodized, it says. I thought they made aluminum kits for our cars? Is the website information wrong? I'd like to get an aluminum hardcoated kit.
Check it out: http://www.aspracing.com/frame.htm
Just ordered mine thru Summit. ASP will drop ship em to me since I wanted the clear hard coat aluminum finish. $110.95 shipped
I guess clear hard coated aluminum is different from the polished/clear coated March pullies I've had in the past. Although not as shiny as the March kit, I wonder if it's a more durable finish
The dullness is caused by the hardcoat anodize. Standard anodizing of a polished aluminum will still be pretty shiny. The hardcoat is essentially a thicker layer of aluminum oxide that is grown on the surface, which will be less shiny, but more protective.STREETFIGHTER50 said:Although not as shiny as the March kit, I wonder if it's a more durable finish![]()
illwood said:The dullness is caused by the hardcoat anodize. Standard anodizing of a polished aluminum will still be pretty shiny. The hardcoat is essentially a thicker layer of aluminum oxide that is grown on the surface, which will be less shiny, but more protective.
There is less room on the SN95 to get to the belt tensioner, especially because it is located on the passenger side down a bit behind the radiator. It's not too bad, but it takes doing it once or twice to get the hang of it.STREETFIGHTER50 said:Thanks illwood, good to know since I really was expecting a glossy/polished finish. Overall they still look really nice tho! Another Q... I haven't installed on a SN95 yet, how different is it from the Foxes? Removing the belt/tension on the Fox is a breeze![]()
