Which pulley kit did u install on ur 94/95 5.0? BBK or March?
STREETFIGHTER50 said:
more q's????
anyone have any cooling charging problems installing these?
also, how about the a/c function? will it still blow cold even at idle?
I don't have any cooling problems after running the U/D pulley kit.
I do notice a drop in voltage if I'm idling at night (the headlights are on). I have run the car with the headlights on, AC on, CD player on, at a stoplight and I noticed the volt gauge too a little while to get back to where it usually is, but it was fine.
illwood said:
I'm running some ASP pullies from Summit. They're black anodized aluminum and go for ~$94.
I was lookin at Autospecialtie's website & could only see "steel" pulley kits for our '94/'95's. They come in 3 different finishes-nitride, zinc, or black anodized, it says. I thought they made aluminum kits for our cars? Is the website information wrong? I'd like to get an aluminum hardcoated kit.
Check it out: http://www.aspracing.com/frame.htm
Oh, heh, that's just a typo that's a carryover from the ASP website. It's correct in the column listing, but incorrect when you click on the link for them. Part of the givaway is that you can't anodize steel. Black oxide, yes, anodize, no.
They are most definitely black anodized aluminum. I bought mine through Summit. Please trust me on this, I am a Mechanical Engineer and a machinist, so I know metals.
Although not as shiny as the March kit, I wonder if it's a more durable finish:shrug:
The dullness is caused by the hardcoat anodize. Standard anodizing of a polished aluminum will still be pretty shiny. The hardcoat is essentially a thicker layer of aluminum oxide that is grown on the surface, which will be less shiny, but more protective.
Thanks illwood, good to know since I really was expecting a glossy/polished finish. Overall they still look really nice tho! Another Q... I haven't installed on a SN95 yet, how different is it from the Foxes? Removing the belt/tension on the Fox is a breeze:D
There is less room on the SN95 to get to the belt tensioner, especially because it is located on the passenger side down a bit behind the radiator. It's not too bad, but it takes doing it once or twice to get the hang of it.
