Which ratio rear end?
I just recently bought a 1965 Fastback restored with a Borg-Warner T5 5-speed and a high performance 302. It dynos at 400HP. The car is a daily driver, but I want to make it competative in the 1/4 mile. What rear end ratio would be best but without taching too high at highway speeds?
Also, is a Detroit Locker the best choice for a limited-slip differential?
What rear end is in the car? What height tires will you be doing your highway driving on?
More then likely you probably want something in the 3.70-3.80 range.
Also, with a t-5 and 400 fwhp you are getting close to the limits of the transmission. I would suggest staying away from powershifting it at all. Oh, and if it doesn't go into third beating on it, let off of it and ride it out. Forcing it into third = pretty loud boom.
we know its possible but its hard to believe it since everyone says they has one these days and don't have the dyno sheet to show for it.
my 306 did 312rwhp/331rwtq thru an AOD which is pretty close to 400 FLYWHEEL horsepower.
Bah with a T5 don't need to fear the gear, plus if you are making that power with a 302 I assume that you are spinning it up there a bit. If you want a good medium go with 3.89's if not go with 4.11's. That is what I will be using. And Detroit Locker all the way Limited Slip sucks.
Cannoball888 said:
I've heard Detroit Lockers are too noisy for a street car. Anyone know if the Detroit SoftLocker is quieter but just as good? And what exactly is a Detroit EZ Locker?
Everybody told me the same thing and talked me out out of one,so my buddy put one in his 65 coupe,i cant even hear it,now i have this TSD from Currie which i think is crap
