Which rear gears?
  • Thread starter Thread starter Gud T.B. Blown
  • Start date Start date Jun 14, 2007
G
Gud T.B. Blown
583
Jun 14, 2007
  • Jun 14, 2007
Here is what I have:
'73 Mach 1
351C with 4V CC heads
Blue Thunder intake
Holley 700 dp
Moderate cam, exact grind still unkown.
Hooker Long tubes with 2.5" pipe and x-pipe
Tremec TKO with .82 OD
275/60R 15 Rear tires
This is strictly a street car that I will take on occasion Highway trips of up to 300 miles. The two choices for rear gears that I'm looking at are 3.55 and 3.70. Any thoughts or recommendations?
SL 1993 R
287
California
Jun 14, 2007
  • Jun 14, 2007
I liked the 3.91's I had in my 71 Boss, nice response getting the big car moving.. but if I were making 300 mile trips regularly, the 3.55's would be my choice... If you can afford the hit on the gas mileage, go for the higher numbered gear..
ratio411
3,870
73
109
Pensacola FL
Jun 14, 2007
  • Jun 14, 2007
With your OD, 3.50 gears = 2.87 final drive and 3.70 gears = 3.04 final.
Having used 3.00 gears for a long time, the 3.04 would be liveable on a long trip, but the 2.87 would be a bit nicer...
I'd have to say use the 3.50s for comfort.
However, it is not a huge difference and the 3.70s would run real nice with your combo.
If you didn't travel, I'd say 3.89/3.91 all the way!
That will give you a 3.20 final drive, which is not bad at all. I have driven 10 hours one way with 3.25s without bother. But gas was cheaper then!
Fwiw:
You have some tall tires there. I base my experience on 26" OD tires!
That 2" difference is pretty huge when applied to gearing.
Also, you want to be able to move that 71, it is a little bigger and heavier.
G
Gud T.B. Blown
583
Jun 14, 2007
  • Jun 14, 2007
I'm not so much worried about the gas mileage as the noise in the car. According the speed analyzer on the Keisler site 70 MPH with a 3.89 is at 2700RPM vs. 2400RPM for a 3.5. Now if I want to go to 75MPH the RPM's go up to 2900RPM with the 3.89 gears.
I'm putting dynamat in the doors and on the floors, how much driveline noise can I expect that to reduce?
ratio411
3,870
73
109
Pensacola FL
Jun 14, 2007
  • Jun 14, 2007
If you are worried about noise, some important things are making sure the exhaust exits as far back as possible, using a tamer muffler (like a Turbo style), and then the insulation helps...
If the gears are set up proper, they will add no noise.
It's the exhaust drone that will make or break your noise situation.
G
Gud T.B. Blown
583
Jun 14, 2007
  • Jun 14, 2007
The drone is the worry.
I don't expect the gears to make any noise because I am going to spend the money to have somebody install them that knows what they are doing. The mufflers are dynomax and I chose them because they made less noise and the exits are at the rear.
I wish there was a way to install them and drive the car around to see the difference without having to pay for it.
Right now looking at the gearing calculator I'm thinking the 3.7 gears.
68RCodeConv
345
Houston, TX
Jun 15, 2007
  • Jun 15, 2007
I've had both 3.89 and 3.50 rear gears behind the 4V Cleveland in my 73 vert. And I've had 3.91 gears on my Boss 351.
Get the 3.70. With the .82 OD they'll be fine on the highway.
And you never said what your first gear ratio is. Makes a big difference when choosing rear end gears.
ratio411
3,870
73
109
Pensacola FL
Jun 15, 2007
  • Jun 15, 2007
What he said...
And 1st gear also makes a huge difference on the strength of the tranny.
A granny 1st gear mixed with a lower rear gear can strain (and/or break) a tranny.
G
Gud T.B. Blown
583
Jun 15, 2007
  • Jun 15, 2007
ratio411 said:
What he said...
The tranny is a TKO 600 and first gear is 2.87:1.
rbohm
6,698
550
204
tucson,az
Jun 15, 2007
#10
  • Jun 15, 2007
  • #10
given the OD ratio, and the first gear ratio, either gear will work just fine. i wouldnt go more than the 3.70 gear though.
C
Suggestions for rear diff gears - 1969 Mach 351W 4v
  • cfauvel
  • Apr 8, 2024
2K
Classic Mustang Specific Tech Jun 27, 2024
cfauvel
C
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
M
My 82 hatch 408 build
  • Miskitobyte15
  • Jun 16, 2018
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2018
Gear grabber
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
