which RR's?
JimmyRGT
118
Atlanta, GA (GA Tech)
Hello soon I am going to puting either AFR 165's or Edelbrock Performers on the ole stang along with a trick flow street heat intake and bbk 70 mm TB. I want to add some roller rockers as well but I dont know size to get. Should i get 1.6's or 1.7's? Is bigger better? And more importantly would i have any valve clearance problems if i got the 1.7's. I have a 95 gt with the stock short block and the stock valve cover right now but i can replace the covers if need be. I would appreciate any help as to which rockers i should get. Thanks.
giddyup306
3,041
99.5% of the time 1.7's will make more power. Also you shouldn't have any clearance problems especially with a stock cam. You usually only run into clearance problems when you get into 300+* of duration.
