If you are asking about levers, a Hurst 538 4106 available from Summit, the shift unit on the transmission is the stock T5. I will change it later to one with a more positive return to center for a better shift to third.
The Hurst lever looks good, comes far enough back to make the 3, 5 shifts with out reaching. It is a little high so one with the same set back but shorter by a couple of inches would work well too. It also has an offset that brings it closer to the driver.
