which speedo gear?
Manual Transmissions with 6 Tooth Drive Gear
Not found in OEM applications
Item Number
Description
N/A
3.08 Gear Ratio / Not possible
C0DZ-17271-A
3.27 Gear Ratio / Maroon 16 Speedo Gear
C3DZ-17271-C
3.55 Gear Ratio / White 17 Speedo Gear
C0DD-17271-B
3.73 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.90 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
4.10 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
4.30 Gear Ratio / Red 21 Speedo Gear
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
Item Number
Description
C0DZ-17271-A
2.73 Gear Ratio / Maroon 16 Speedo Gear
C0DD-17271-B
3.08 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.27 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
3.55 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.73 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
Item Number
Description
C0DD-17271-B
2.73 Gear Ratio / Yellow 18 Speedo Gear
C1DZ-17271-A
3.08 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.27 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
3.55 Gear Ratio / White 23 Speedo Gear
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
Item Number
Description
D0AZ-17271-A
2.73 Gear Ratio / Blue 16 Speedo Gear
C7AZ-17271-B
3.08 Gear Ratio / Gray 18 Speedo Gear
C7VY-17271-A
3.27 Gear Ratio / Tan 19 Speedo Gear
C8SZ-17271-B
3.55 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.73 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
Item Number
Description
C7AZ-17271-B
2.73 Gear Ratio / Gray 18 Speedo Gear
C8SZ-17271-B
3.08 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.27 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Now if you really want to change the internal drive gear of your manual tranny you can match it according to the table below. Be aware that the 6 tooth will offer the most combos for numerically higher gear ratios and offer the greatest degree of accuracy. The 6 tooth gear selection table for a manual tranny is the first in the page.
Item Number
Description
E3ZZ-17285-B
6 Tooth Internal Drive Gear / Black
E3ZZ-17285-A
7 Tooth Internal Drive Gear / Yellow
F0ZZ-17285-A
8 Tooth Internal Drive Gear / Green
Watch out you don't wind up with junk floating around in your tranny. I had a white (23 tooth) gear in my T-5 tranny (with the 8 tooth drive gear) and the plastic teeth were partially eaten off. I've heard others complaining on different forums that this is a common problem because the teeth don't quite line up. I now use the red (21 tooth) gear and have not had any repeat dental problems. The speedo is off about 11% and I just calculate my speed. Maybe like Grady said the Speedcal thing might be the best option if you need an accurate speedo.
Roland69--that is a fantastic reference on the speedometer gears. Thanks.
