  • 1994 - 1995 Specific Tech
Which subframes for a vert?
  • Thread starter Thread starter DarkProphet
  • Start date Start date Apr 26, 2007
DarkProphet
391
Quakertown, PA
Apr 26, 2007
  • Apr 26, 2007
I have another question for you all. I'm pretty much finished with the power plant (I may port the lower this winter), but I need ALOT of other things. I just ordered a set of 13" cobra brakes so I can actually stop from 140 haha. My next purchase is going to be subframe connectors, and I've read alot of reviews but not really too many for verts. I was thinknig the MM full lengths, but Im not sure if they work on a vert? Also, my car is kind of low, is this going to make things worse??
Thanks a lot:SNSign:
Killercanary
The car that set the bar.
Altoona, PA
Apr 26, 2007
  • Apr 26, 2007
My vote goes to http://www.globalwest.net. No lack of ground clearance, they are full length, and they are 'vert specific. I've had mine for years and LOVE them, I wouldn't run any other set on my car.
DarkProphet
391
Quakertown, PA
Apr 26, 2007
  • Apr 26, 2007
Thanks for the reply killer! I was hoping you would actually...
Are these the ones your talking about:
They also have a seat brackets available too. Did you get them as well?
chaos254
467
NJ
Apr 26, 2007
  • Apr 26, 2007
i run the MM full length on my vert and with no problems...
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Apr 26, 2007
  • Apr 26, 2007
Im more interested in the ground clearance issue.
D
Danman765432
471
Nutley, NJ
Apr 26, 2007
  • Apr 26, 2007
I have a set of Full Length Maximum Motorsports for a vert sitting in my basement if you want pictures...They are the full length ones...I should be getting them put on this weekend or next.
chaos254
467
NJ
Apr 26, 2007
  • Apr 26, 2007
i have no ground clearance issues at all... their tight up against the frame.
1TallMF
955
Montreal
Apr 26, 2007
  • Apr 26, 2007
I'm looking at getting the full-length MM ones as well but I'm worried I won't be able to put my car on the hoist anymore with them. I hoist my car from the flat spots in front of the rear LCA's and at the front part of where the frame rails stop before the K-member. Don't the full-length ones install directly onto the bottom of these two spots? Or do they weld-up beside them? Anyone have any pics of them installed? I can just barely fit the 4 hoist pad thingys under my car when its on the ground, I'd hate to lose the ability to get my car on a hoist for lack of ground clearance.
'94ChickStang
301
northern ca
Apr 26, 2007
  • Apr 26, 2007
I'm with Paul all the way, I spent waaaay too much on the #929C but hopefully it pays dividends in the long run! It felt great after the install too...check oyut the website.
V
Voice of Reason
70
Spring, TX
Apr 26, 2007
#10
  • Apr 26, 2007
  • #10
I have the MM full length ones on mine. Made a nice difference. If you go with these DO NOT get them pre-powdercoated or painted. The person welding them on will have to scrape down to bare metal where he has to attach them to the car. My shop was very appreciative when they saw I got them bare. At the end they just sprayed them with black paint and you can't even tell they are there.
Stanger007
2,015
Baton Rouge, LA
Apr 26, 2007
#11
  • Apr 26, 2007
  • #11
I went with the powdercoated MM full-length. Look amazing and work even better.
Wes
DarkProphet
391
Quakertown, PA
Apr 26, 2007
#12
  • Apr 26, 2007
  • #12
Thanks for all the input guys! I was ordering a few things from 50resto, and ordered a set of MM full lengths while I was on there. Now I just have to get them installed....
True 5.0
237
Southeastern Wisconsin
Apr 26, 2007
#13
  • Apr 26, 2007
  • #13
Make sure they get welded in and not bolted!!
Killercanary
Altoona, PA
Apr 26, 2007
#14
  • Apr 26, 2007
  • #14
I do have the seat tie-ins with my subframes.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
