  • 1994 - 1995 Specific Tech
which tool?
  • Thread starter Thread starter deadlast
  • Start date Start date Apr 10, 2005
deadlast
495
Belmont, MA
Apr 10, 2005
  • Apr 10, 2005
i cant reach my header - h pipe bolt because of the damn cats. whats the best tool to get up there and loosen the bolts? should i try to loosen them from the bottom or top? any other helpful hints for switching h pipes?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 10, 2005
  • Apr 10, 2005
To remove the H-pipe your going to want some socket wrench extensions (I use the 6" ones and 3" ones). You will want a swivel socket as well to contort to what you need.
Spray some wd40 or Liquid Wrench equivalent on the bolts to soak to help you remove them.
Unplug your 02 sensor connections. I use a skinny flathead screwdriver to depress the connector.
Good Luck
2L8ULUZ2
Will kiss Moderator ass for title
3,033
14
99
WNC
Apr 10, 2005
  • Apr 10, 2005
You will need to go in from the bottom and use a looooonnnnnggggg extnesion and a wobble attachment to get the bend that you need to get up there. If it has never been removed before then get some penetrating lube for it and lay hell to it with it. A impact gun will also make life much easier too.
donkey_punch
565
northern****ingjersey
Apr 10, 2005
  • Apr 10, 2005
by any chance would someone know what size socket to put on the end of the swivel and extention?
i will be going through this is a couple of weeks.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 10, 2005
  • Apr 10, 2005
I believe it is 5/8's or 11/16th's which worked for me. The bolts might actually be metric but if you can get the standard socket on there "straight" it won't strip...
deadlast
495
Belmont, MA
Apr 10, 2005
  • Apr 10, 2005
app. how long of a task is it, if i dont have too much trouble with the bolts?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 10, 2005
  • Apr 10, 2005
For a first timer and having a friend just expect 2 hours for the install although many can get it on and off quicker than that...just take your time and have patience (calmness) and it should go on and come off smooth as butter
Jack the car up safely (a lift would be even better). Get the bolts semi-snug and when you get the exhaust to fit like you want it and check for clearance issues tighten them all down to a final torque. Recheck the bolts in a week or so to see if they have loosened...
Good Luck
deadlast
495
Belmont, MA
Apr 11, 2005
  • Apr 11, 2005
found this kit at summit, and since ill be getting the pipe from there, thought id get this too. would this suit the task at hand?
search for SUM-W38911
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 11, 2005
  • Apr 11, 2005
Let's see: It has two different extensions and a swivel attachment...yep it will do
Just have patience and if you need more leverage to break the manifold to H-pipe bolts you can put a hollow bar over your socket wrench for more leverage. It works nicely...
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
