which trans do i need
  • Thread starter Thread starter 91drag
  • Start date Start date Feb 12, 2007
9
91drag
32
  • Feb 12, 2007
will a c-4 out of a 70 model fit my 66 289 or will i have to change driveshaft lenth. i have a 6 bolt bellhousing. will i need a small bell housing trans or a big bell housing trans. its all factory with a green dot c-4 cruise-a-matic .
D
D.Hearne
11,730
south louisiana
Feb 12, 2007
  • Feb 12, 2007
Yea, it should fit. Measure the length, but I doubt there's a change there. You'd also want to retain the 157 tooth bell.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Feb 12, 2007
  • Feb 12, 2007
Lots of questions.
Like D. Hearne mentioned it should fit.
You'll want the Small block bellhousing. Not sure if the C4 ever came behind a big block.
9
91drag
32
  • Feb 12, 2007
i was just asking because on summit on the tci trans it says that for the 289-302 it askes if pan filled or case filled and big and small bellhousing
D
D.Hearne
11,730
south louisiana
Feb 12, 2007
  • Feb 12, 2007
Pan fill was the 69-later 164 tooth bell C-4 also referred to sometimes as a C-5. This is a heavy duty unit used in the bigger cars, trucks and vans. There were 3 size flexplate C-4's, 147 (Mustang II only), 157 and 164. You want the 157 tooth case fill transmission. I'm not 100% sure but you're present bell should fit it. If someone else knows, speak up.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
