Which trans fluid to use in my 5-speed?
daddystang
185
I bought a Super HD T-5 from Summit last summer which says Tremec on the body of it, and there was a tag on it that said "this transmission must be filled with ATF". I filled it with ATF synthetic Castrol. It seems to be ok, and shifts good though a little noisy at times. The reason I'm asking is a friend told me I was crazy for using automatic trans fluid in a 5-speed, and said I should use the manual trans fluid. Any one know for sure which I should be using? :shrug: Thanks guys, just want to make sure I'm doing things correctly.
Thanks in advance....
Mobil 1 fully-synthetic ATF would also be a good alternative, since Mercon V is only a synthetic blend (instead of 100% synthetic). Might last ya' a bit longer, as it seems to hold up better against thermal breakdown over time.
