69gmachine said:There is no difference in nickel content, however there is a big difference in the amount of material in the main webs. At one time I had a complete list of casting numbers and what the running changes were, but it went into bit heaven when my last hard drive crashed. So from my memory, all I can tell you for certain is that the C90E (9.48 dh) and D1AE (9.501 dh) castings are the most desirable. They were cast with bosses for 4 bolt mains and thick main webs. Unfortunately they never received the 4 bolt caps from the factory, but they are easily converted. They weigh about 8-10 lbs more than the D2AE and D4AE blocks that followed. If you look at the underside of them side by side with the later blocks it's obvious how much beefier they are. There was an E3TE or E4TE truck block that came with thick main webs also, but I was never able to get any specs on it for comparison to the C9 and D1 blocks. The C9 blocks were used in '69 and '70 Mustangs, Fairlaines and anything else that got a 351W. The D1 was only used in full size cars in '71 only as the mid size sporty cars got the 351C, and in '72 they cast a new wimpy block, so they are pretty rare.
1320stang said:I've got a '69 block, but for the life of me, I can't find the main caps. I considered either buying a set of used main caps off Ebay (hard to find) or Pro Gram Engineering's billet main caps, the center 3 are 4 bolt, but the whole billet set would be $583.54!!!! And either way, you still have to have it line bored. If I could at least find the front and rear cap, the center 3 PGE caps are $240 which is much more reasonable, but line bore and machine and tap the outer holes for the center caps are still in order.
1320stang said:Hmmm.... my .060 over '65 289 block with no grout has turned 8000 rpm regularly with a '65 cast crank and taken a 3000# car to 11.0s with a Jerico and 5.67 gears w/ 9x30 slicks with no sign of a bore splitting. Maybe I'm not running it hard enough?![]()
are the X's cast in the lifter valley? Whats the datecode?triostang said:i have a block with the x's on it, know what that means?
mustangdave said:bnicknel, the rods are very weak stock on the 351W. I have a theory on 351W mains, let me lnow what you think. Due to the larger main journals, they hold more heat and do not like high r.p.m.'s (over 6,000 on a regular basis).
