- Apr 21, 2004
- 57
- 0
- 0
Terror strikes the heartland. I was installing my white face gauges and failed to note the original location of my needles before ripping them off. Ooops. Any suggestions??? Thanks.
I was gonna suggest pacing a friends car with the speedo lense off at a determined speed then replace the needles if you didn't damage the shafts during the 1st installation.
Go out to you car (optional) and look at the gauges notice that there is a little pin that your needles rest on when the car is shut down. When you change your overlays you have to remove that pin, keep in mind that there are wound up springs behind your needles which helps them to return to the pin when the car is shut down that is why you have to make a recording of the gauge needles I don't think that "eyeballin" will work, not if you want it to be accurate because once the pin is removed the needle will fall beyond the pin. You do always have the option of taking it to a professional who can re-calibrate it for you I know of only one person who has actually done this and he goes by bad91lx I believe he paid $75. Now as far as removing the stock overlays in preparation for the new ones I have no clue because I used NR Elglo gauges so I did'nt have to do that but the removal is the same. I painted my needles with plasti-kote Odds 'n' Ends fast dry enamel (Orange Glow B27) which I got at WalMart it matched perfectly with the needles on my Autometer gauges, some have chosen to use hobby paint (Testors) which you may have to mix to get the desired color.
Did you paint the whole needle so it looked like the AutoMeter needles, or just paint the bottom so it would still illuminate?patdow1 said:I painted my needles with plasti-kote Odds 'n' Ends fast dry enamel (Orange Glow B27) which I got at WalMart it matched perfectly with the needles on my Autometer gauges, some have chosen to use hobby paint (Testors) which you may have to mix to get the desired color.
sweet93hatch said:Terror strikes the heartland. I was installing my white face gauges and failed to note the original location of my needles before ripping them off. Ooops. Any suggestions??? Thanks.
I scraped the white paint from underneath the needle and painted the top and sides so the light could come thru and light up my needles a nice orange.stangbear427 said:Did you paint the whole needle so it looked like the AutoMeter needles, or just paint the bottom so it would still illuminate?
PICS!
