white face guage install??????HELP
  • Thread starter Thread starter Humboldt5.0
  • Start date Start date Oct 5, 2007
H
Humboldt5.0
Banned
Jun 8, 2007
tigard,oregon
Oct 5, 2007
  • Oct 5, 2007
Im trying to put in my white face guages today.They just came in the mail,wheee!.I dont know the easiest way to remove the plastic case covering the guage cluster????? any ideas
fastford91
254
Niagara ,Ontario, Canada
Oct 5, 2007
  • Oct 5, 2007
you have to take the dash out on the drivers side! its very easy !first you need to unscrew the 2 screws at the top of your dash ! you should be able to see them by looking into the car through your front window! then right around where your knees are the are 2 bolts on each side! undo these blots! pull the plastic cover off! then it should expose the rest of the bolts you need to get the rest off! go slow and easy !! its a bit confusing the first time you do it! just remember the order in which you took them off and put them back on the same! when you get to the gage cluster its self you will need torx bits to take it out! if you need more detailed info just ask but this should get you going!
cenok is family
1,409
69
79
Norman, Ok
Oct 5, 2007
  • Oct 5, 2007
pretty much like that! except you can use an 8mm (might be 7mm, don't remember exactly!) socket on the clear cover on the gauge cluster if you don't have a torx bit! good luck! weee!
H
Humboldt5.0
Banned
Jun 8, 2007
tigard,oregon
Oct 5, 2007
  • Oct 5, 2007
ok guys,i have it all apart and the olnly thing holding me up is the speedo needle????? i dosnt seem to want to slide off easy like the others??any tricks,i dont want to breake it.
cenok is family
1,409
69
79
Norman, Ok
Oct 5, 2007
  • Oct 5, 2007
you gotta take the black part off first, and then pull the needle. do NOT lose the black caps though, your speedo will say you're going wwaayy faster than you are if you don't have the cap.
H
Humboldt5.0
Banned
Jun 8, 2007
tigard,oregon
Oct 5, 2007
  • Oct 5, 2007
ok........do you suggest using pliers to remove the needle?
H
Humboldt5.0
Banned
Jun 8, 2007
tigard,oregon
Oct 5, 2007
  • Oct 5, 2007
bammmm! it just popped off! i will keep oyu posted to see if i can put it all back together.Thankyou again guys...u kick butt
cenok is family
1,409
69
79
Norman, Ok
Oct 5, 2007
  • Oct 5, 2007
cool. glad it's working out for ya. post some pics when you're finished
fastford91
254
Oct 5, 2007
  • Oct 5, 2007
glad to hear you got it off ! good luck with the install
H
Humboldt5.0
Banned
Jun 8, 2007
tigard,oregon
Oct 5, 2007
#10
  • Oct 5, 2007
  • #10
whew! took me about 5 hours but the white faces are in! Im very happy with the install but wish i had done the blue bulbs in while it was tore down.oh well that gives me another project to do right.Oh by the way i used the APC ebay kit(32$ delivered).....i figured i would sacrifice and try the cheap kit to let you know how the looked and worked. the check engine light cant be seen,but everything else looks ok.ist no dark yet bu had to take a quick pic.
fastford91
254
Oct 5, 2007
#11
  • Oct 5, 2007
  • #11
looks good!! i have the white face guages as well ! but i can change mine by pushing a button from green to blue and purple! looks sweet at night! when it gets dark take another pic and post it!! id like to see what it looks like!
H
Humboldt5.0
Banned
Jun 8, 2007
tigard,oregon
Oct 5, 2007
#12
  • Oct 5, 2007
  • #12
at night not really a diffrent from stock??oh well i wanted the clean look for daytime anyway.....dam i want the blue bulbs......mabey next week,lol
looks like i need a new bulb anyway? some of the numbers arent as bright as others...mabey thats why the kits cheap
oh the little line of light under the tach is what shows up from the check engine light that just came on last week at about 97,000 miles oil is good so?????
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:09 PM
2000xp8
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
