White "gunk"
  • Thread starter Thread starter gungfusemaj
  • Start date Start date Dec 26, 2003
gungfusemaj
211
Bradenton Fl
Dec 26, 2003
  • Dec 26, 2003
I am replacing a manifold system and when I took off the hose going to the water neck I notice a good amount of white junk built up around the inside kind of looked like old lumpy milk stuck to the side of the glass....any ways I have a new radiator to replace the old but what would cause somthing like that????? 87 gt
gungfusemaj
211
Bradenton Fl
Dec 26, 2003
  • Dec 26, 2003
anyone
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 26, 2003
  • Dec 26, 2003
Possible excess sealant from the lower row of head bolts that go directly into the water jacket. Each of the lower head bolts is supposed to be coated with a sealant to keep them from seeping coolant past the threads.
The local speed shop in my area (Powered By Ford) said to use teflon pipe dope, which is white.
BlackFox5.0
3,514
Massachusetts
Dec 26, 2003
  • Dec 26, 2003
Or it could just be oxidation
J
jerry beach
2,671
Ocala,FL
Dec 26, 2003
  • Dec 26, 2003
I dont know, but flush your system with the old rad in there and the heater on before you change your rads. Otherwise you will have junk in your new one.
gungfusemaj
211
Bradenton Fl
Dec 26, 2003
  • Dec 26, 2003
how do you "flush"
ashford
485
fargo ND
Dec 27, 2003
  • Dec 27, 2003
pull the heater hose off your water pump, put a garden hose in the radiator, turn on hose and run engine till you get pure and clear water out of it. only thing is to get out as much water as you can out of the engine, put in pure antifreeze when done, look in your repair manual and find out the water capacity and put exactly half of that in for coolant the rest shoud be water.
also if your new radiator is bigger you need more coolant in it
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
