- Apr 29, 2008
- 148
- 0
- 0
Hey all,
I have a leaky A/C system in my 2002 GT Vert. A few days ago I started up my car and noticed it was blowing hot air. This pretty much happened overnight. One day it works, the next it doesn't. So I pop the hood to check it out and I noticed that the A/C compressor clutch was intermittently operating. I jumpered the Low Pressure Sensor Switch and the A/C compressor functioned just fine.
Ok, so at this point I'm thinking low refrigerant so I head to Auto Zone and get a can of recharge.
I charge the system to about 40 psi, or until the can was empty.
Two days later my A/C is blowing hot air again and my clutch is cycling again so OBVIOUSLY I have a leak somewhere. The recharge I added had UV dye in it to detect leaks but I haven't had a chance to take a UV light to it and find my leak.
I have read on some threads to replace the O-rings in the system to cure a leak.
My question is this: Where are the common places a mustang's A/C system would leak from? I know this can happen pretty much anywhere in the system, but are there common problems you have experienced?
Thanks a lot, I will post pics as soon as I take the UV light to it.
