who traps 104+ with BASIC bolt ons?
Daniel50 said:
anyone trap 104 with everything bolt ons excluding heads, cam, nitrous, supercharger, and turbos everything else is ok. rockers and up basically.
I'm not a big drag racer anymore, but that's weird that you run almost a 13 at 110 mph.. on my crotch rocket I used to run 12 flat at 110 mph.
in ur sig it says you already have that... I'm confused w/ this thread - write down all your mods that you ran a 102 trap speed with, w/o spray if i'm correct, than ask your question lol !!
Paul Perreca
a few years ago my hatchback went 13.2 at 104.2 consistantly with the following...
Cobra intake
65mm throttle body
73mm maf
mac cold air kit
underdrive pullies
MSD 6a
aluminum driveshaft
1 5/8in shorty headers
2 1/2in off road h-pipe
2 1/2in mac cat back
2800rpm lockup stall converter
3.73s
timing at 14 degrees
3260 lb race weight
So basically 104+ with the stock untouched longblock? Trap speeds take horsepower and it's hard to get good horsepower throught though those stock heads and a small stock cam. I bet the best way would be to concentrate on weight reduction to increase the power to weight ratio.
104.0mph with stock long block, stock TB, stock waterpump... car has no weight reduction, mph was run in 2600' d/a. ... which is about 109mph at sea level.
valve covers were never off.
n/a.
